enot767 Posted April 25, 2005 Report Share Posted April 25, 2005 ok so sonicstage version 3, and netmd simple burner version 2, dont work....after a "power short" or what not i have been have a big pain the the ass getting my music onto my netmd, while i was recording the "power short" accured so i dont know what wrong, i unpluged the power to the device, put a new battery in, new md disk, redownloaded the programs such as sonic stage and simply burner..here, heres a few pics u can look at.... http://img188.echo.cx/img188/2433/16fw1.jpg - netmd simple burner recording error http://img188.echo.cx/img188/8996/22vl.jpg - sonic stage transfer count errorhttp://img188.echo.cx/img188/9553/35iu.jpg - sonic stage format errorso can someone plz help me Quote Link to comment Share on other sites More sharing options...
Ascariss Posted April 27, 2005 Report Share Posted April 27, 2005 Hmm interesting.I am wondering where the power short occured, to the PC I presume? And not the MD and it wasn't effected in anyway? Since if the MD was damaged it might not record now, again not sure since it could be the PC.Assuming the MD is fine, maybe disc is write protected and you need to switch it back to unprotected, it's happened a few times to me after I switch it not to lose data, simple mistake, just checking again. If that's not the problem, maybe the song you are transferring is not allowed to be transferred. I have had this problem with one song once. It won't transfer as a MP3 only a wav file, which I make after conversion from MP3>>WAV.I'm going to go out on a limb and say the MD could be malfunctioning but that's not 100% certain or proven here. Maybe try recording from something else using the line in and see if it records, if it doesn't then I say the MD is damaged, if it records, it's the software. btw, what is your OS? XP? if so is it all updated, that could be a problem, maybe there is another program running and conflicting with SS. Quote Link to comment Share on other sites More sharing options...
atrain Posted April 27, 2005 Report Share Posted April 27, 2005 please follow the rules posted in the sticky at the top of this forum. post pc specs, which md unit you have, whether it will operate in non net mode. Quote Link to comment Share on other sites More sharing options...
Syrius Posted April 28, 2005 Report Share Posted April 28, 2005 May I suggest you close as many other applications that you have running on the background? SonicStage is a resource hog. Quote Link to comment Share on other sites More sharing options...
enot767 Posted May 1, 2005 Author Report Share Posted May 1, 2005 computer - ACPI MultiprocessorHard Drives - WDC WD1200LB-00ED0 USB device WCD WD200BB-00CAA1Display adapters (video card) - NIVIDIA GeFOrce FX 5600DVD/CD-ROM - Sony DVD RW DW-U10AFloppy disk drive - Floppy disk driveIDE ATA/ATAPI contollers - Intel 82801EB Ultra ATA Storage Controllers Primary IDE Channel Secondary IDE ChannelIEEE 1394 Bus host controllers - VIA OHCI Complaint IEEE 1394 Host ControllerProcessors - Intel Pentium 4 CPU 2.40Ghz Intel pentium 4 Cpu 2.40GHzRam - 1 Gighope thats enough...(im pretty sure it is ) if not tell me what you need i have soo much more Quote Link to comment Share on other sites More sharing options...
Christopher Posted May 1, 2005 Report Share Posted May 1, 2005 What operating system and service pack do you have? Quote Link to comment Share on other sites More sharing options...
atrain Posted May 2, 2005 Report Share Posted May 2, 2005 also what colour is the case? does it have all crazy lights & shit on it? Quote Link to comment Share on other sites More sharing options...
Christopher Posted May 2, 2005 Report Share Posted May 2, 2005 lol, you're a nut atrain. Quote Link to comment Share on other sites More sharing options...
